Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Pull the orange lever and the battery will spring out slightly.
Grasp the battery and fully pull it out of its slot.
Locate the sliding button labeled "CF OPEN."
Place your finger on the button and slide it in the direction of the arrow.
The side panel will flip open revealing the compact flash memory card.
Locate the gray button at the bottom of the open slot.
Place your finger on the button and push it down.
The memory card will pop out slightly.
