Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the grey latch to open the battery compartment.
Push and slide the orange retaining clip to the right to remove the battery.
Position the camera so that the bottom is facing up.
Remove the two 2.3mm screws beneath the name plate.
Remove the two 2.8 mm screws surrounding the threaded tripod mount.
Remove the 3.8mm screw from the back face of the camera.
Remove the two 2.3mm screws from the right face of the camera.
Remove the two outer 3.2mm screws from the left side of the camera
Remove the two inner 3.7mm screws from the left side of the camera.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Remove the CF card door from the left side of the camera body.
Slide the rubber digital a/v cap out of place on the front plate.
Remove the rubber seal that covers the right side of the viewfinder.
Remove the two 3.9mm screws that hold the laminated copper sheet.
Remove the wire connections that connect along the bottom of the motherboard.
Remove the single 3.8mm screw that is on the motherboard.
Remove the motherboard from the main frame of the camera body.
