Ga door naar hoofdinhoud
Canon Powershot S200 Motherboard Replacement
Wat je nodig hebt
  1. Canon Powershot S200 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Canon Powershot S200 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: stap 2, afbeelding 1 van 2 Canon Powershot S200 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: stap 10, afbeelding 1 van 2 Canon Powershot S200 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: stap 11, afbeelding 1 van 2 Canon Powershot S200 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: stap 15, afbeelding 1 van 2 Canon Powershot S200 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the motherboard from the main frame of the camera body.
Conclusie
Orlando Zuniga
11 Reputatie
1 Handleiding geschreven
Cal Poly, Team 20-70, Walters Spring 2011 Lid van Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,908
