Ga door naar hoofdinhoud
Canon Powershot A70 Rear Exterior Panel Replacement
Wat je nodig hebt
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: stap 1, afbeelding 1 van 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: stap 3, afbeelding 1 van 3 Canon Powershot A70 Rear Exterior Panel Replacement: stap 3, afbeelding 2 van 3 Canon Powershot A70 Rear Exterior Panel Replacement: stap 3, afbeelding 3 van 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: stap 4, afbeelding 1 van 2 Canon Powershot A70 Rear Exterior Panel Replacement: stap 4, afbeelding 2 van 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: stap 5, afbeelding 1 van 1
    • The interior of the camera should look like this.
Conclusie
Shalan Ertis
68 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-40, Regan Winter 2010 Lid van Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 3,277
