Inleiding
Use this guide to replace a Canon Powershot A70 Front Exterior Panel. The front exterior panel is used as an outside casing for the wiring of the camera. Before starting the guide, make sure you remove the camera's batteries.
Wat je nodig hebt
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
