Ga door naar hoofdinhoud
Canon Powershot A610 Camera Housing Replacement
Wat je nodig hebt
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: stap 1, afbeelding 1 van 2 Canon Powershot A610 Camera Housing Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: stap 2, afbeelding 1 van 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: stap 3, afbeelding 1 van 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: stap 3, afbeelding 2 van 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: stap 3, afbeelding 3 van 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: stap 4, afbeelding 1 van 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: stap 5, afbeelding 1 van 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: stap 6, afbeelding 1 van 2 Canon Powershot A610 Camera Housing Replacement: stap 6, afbeelding 2 van 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: stap 7, afbeelding 1 van 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: stap 8, afbeelding 1 van 2 Canon Powershot A610 Camera Housing Replacement: stap 8, afbeelding 2 van 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: stap 9, afbeelding 1 van 2 Canon Powershot A610 Camera Housing Replacement: stap 9, afbeelding 2 van 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: stap 10, afbeelding 1 van 3 Canon Powershot A610 Camera Housing Replacement: stap 10, afbeelding 2 van 3 Canon Powershot A610 Camera Housing Replacement: stap 10, afbeelding 3 van 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Matthew Ramirez
625 Reputatie
5 handleidingen geschreven
Cal Poly, Team 11-26, Maness Winter 2011 Lid van Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 9,088
