Ga door naar hoofdinhoud
Canon PowerShot SX620 HS LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot SX620 HS LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Open the battery door located on the bottom of the camera.
    • Push the orange tab until the battery springs upwards and out.
    • Remove the battery from the camera.
  2. Canon PowerShot SX620 HS LCD Screen Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 4 mm screws from the side of the camera with the flash assembly using a Phillips #000 screwdriver
    • Make sure to keep your screws from different steps separate.
  3. Canon PowerShot SX620 HS LCD Screen Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 2 mm screws from the bottom of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX620 HS LCD Screen Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the single 4 mm screw from the other side of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX620 HS LCD Screen Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Open the HDMI cover.
    • Remove the single 4 mm screw inside the HDMI cover using a Phillips #000 screwdriver.
  6. Canon PowerShot SX620 HS LCD Screen Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Use a plastic opening tool at the top of the camera to loosen the back piece of the outer case. Once it is loose, pull it straight out.
    • Use the same technique to remove the front piece of the camera case.
  7. Canon PowerShot SX620 HS LCD Screen Replacement: stap 7, afbeelding 1 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 7, afbeelding 2 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 7, afbeelding 3 van 3
    • Place the camera with the LCD screen facing up.
    • Pull the side cover pieces out.
  8. Canon PowerShot SX620 HS LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Flip the camera over so the lens is facing upwards.
    • Use the Phillips #000 screwdriver to remove the screw located near the photo button.
  9. Canon PowerShot SX620 HS LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Detach the orange connector from the lens piece using tweezers.
    • Be extremely careful with any of these connectors. They are very fragile and contain important electronic components. If one is damaged, your camera will not work at all.
  10. Canon PowerShot SX620 HS LCD Screen Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Grab the top cover piece directly above the lens. Pull upward to remove it from the camera body.
  11. Canon PowerShot SX620 HS LCD Screen Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SX620 HS LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Use the Phillips #000 screwdriver to remove the two 2 mm screws from the button panel.
  12. Canon PowerShot SX620 HS LCD Screen Replacement: stap 12, afbeelding 1 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 12, afbeelding 2 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 12, afbeelding 3 van 3
    • Use tweezers to carefully detach the connector that is hidden underneath the button panel.
    • Be careful not to damage anything on the motherboard underneath.
    • Flip the button panel upward.
  13. Canon PowerShot SX620 HS LCD Screen Replacement: stap 13, afbeelding 1 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 13, afbeelding 2 van 3 Canon PowerShot SX620 HS LCD Screen Replacement: stap 13, afbeelding 3 van 3
    • Flip the small black cover upward so you can remove the large orange connector. Carefully remove this connector and the smaller connector holding the LCD screen in place.
    • Lift the LCD screen out of the metal frame.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 81
Altijd: 2,091
