Ga door naar hoofdinhoud
Canon PowerShot SX60 HS Top Cover Replacement
Wat je nodig hebt
  1. Canon PowerShot SX60 HS Top Cover Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Top Cover Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX60 HS Top Cover Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Top Cover Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX60 HS Top Cover Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Top Cover Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX60 HS Top Cover Replacement: stap 4, afbeelding 2 van 2
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Top Cover Replacement, Front Panel: stap 5, afbeelding 1 van 2 Canon PowerShot SX60 HS Top Cover Replacement, Front Panel: stap 5, afbeelding 2 van 2
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
  6. Canon PowerShot SX60 HS Top Cover Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot SX60 HS Top Cover Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot SX60 HS Top Cover Replacement: stap 6, afbeelding 3 van 3
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Top Cover Replacement: stap 7, afbeelding 1 van 1
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
  8. Canon PowerShot SX60 HS Top Cover Replacement, Top Cover: stap 8, afbeelding 1 van 1
    • Remove one silver 2mm #00 Philips screw on the front side located next the flash assembly.
  9. Canon PowerShot SX60 HS Top Cover Replacement: stap 9, afbeelding 1 van 3 Canon PowerShot SX60 HS Top Cover Replacement: stap 9, afbeelding 2 van 3 Canon PowerShot SX60 HS Top Cover Replacement: stap 9, afbeelding 3 van 3
    • Use the black spudger to unclip the ribbon on the top right corner and then remove it using the nylon tipped tweezers.
    • Remove one silver 2mm #00 Philips screw found underneath the ribbon.
    • Once the screw is removed, the top panel is completely detached from the device. To remove it, grab it by hand and gently pull it off the device.
Conclusie
Één opmerking
I have a Canon SX610 HS Powershot and it has given me years of good service. Today, I powered it on but could not power it off again without removing the battery. Please help on this problem. Thank you and regards, Ivan (South Africa)
radnet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 513
