Inleiding
This guide shows how to replace the Internal Button Sensor Plate for the Canon PowerShot SX530 HS.
Wat je nodig hebt
Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
Press into the grooves of the battery door and slide the panel in the direction of the arrow.
Flip over the camera.
Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
Use the Phillips PH000 to remove the 4mm screw near the USB port.
Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
Rotate the camera to locate the side with the LCD screen.
Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
Use a Phillips PH000 to remove the two 3mm screws on the panel.
Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
Één opmerking
Przy najkrótszych śrubkach jest problem zich wyjęciem z otworu. POtrzebny śrubokręt z namagnesowanym czubkiem.
