Ga door naar hoofdinhoud
Canon PowerShot SX520 HS Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot SX520 HS Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Motherboard Replacement, Back Face: stap 3, afbeelding 1 van 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: stap 3, afbeelding 2 van 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: stap 3, afbeelding 3 van 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Motherboard Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot SX520 HS Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Motherboard Replacement, LCD Screen: stap 7, afbeelding 1 van 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: stap 9, afbeelding 1 van 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: stap 9, afbeelding 2 van 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: stap 9, afbeelding 3 van 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Motherboard Replacement, Lens: stap 10, afbeelding 1 van 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Lift up the lens by grabbing the sides with your fingers.
  12. Canon PowerShot SX520 HS Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Remove 1-2.5 mm screw using a Phillips #000 screwdriver.
  13. Canon PowerShot SX520 HS Motherboard Replacement: stap 13, afbeelding 1 van 2 Canon PowerShot SX520 HS Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Disconnect the two orange serial cables at the top of the motherboard using your fingers.
    • Gently remove the motherboard using your fingers.
    • Too much force will break the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kyle Crowley
337 Reputatie
3 handleidingen geschreven
Baylor, Team 4-4, Williams Fall 2015 Lid van Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 944
