Ga door naar hoofdinhoud
Canon PowerShot SX520 HS Metal Plate Replacement
Wat je nodig hebt
  1. Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: stap 1, afbeelding 1 van 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: stap 1, afbeelding 2 van 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: stap 1, afbeelding 3 van 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  2. Canon PowerShot SX520 HS Metal Plate Replacement: stap 2, afbeelding 1 van 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  3. Canon PowerShot SX520 HS Metal Plate Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX520 HS Metal Plate Replacement: stap 3, afbeelding 2 van 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Metal Plate Replacement: stap 4, afbeelding 1 van 1
    • Once all screws are removed, pull the back facing off with your fingers.
  5. Canon PowerShot SX520 HS Metal Plate Replacement, LCD Screen: stap 5, afbeelding 1 van 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Metal Plate Replacement: stap 6, afbeelding 1 van 1
    • Carefully pop out the LCD screen with your fingers.
  7. Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: stap 7, afbeelding 1 van 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: stap 7, afbeelding 2 van 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: stap 7, afbeelding 3 van 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
Conclusie
Lisa Choe
460 Reputatie
3 handleidingen geschreven
Baylor, Team 4-4, Williams Fall 2015 Lid van Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 239
