Inleiding
Replace the motherboard of the Canon PowerShot SX50 HS.
Wat je nodig hebt
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
Remove the four #000 Phillips screws, 2 mm in length, from the metal plate.
Remove the one #000 Phillips screw, 5 mm in length, from the metal plate.
Lift the metal plate off with your fingers.
To remove the topmost wire ribbon on the I/O board, lift up the brown latch, and then carefully pull out the ribbon. You can use your fingers or the tweezers.
Remove the wire ribbon on the top left corner of the I/O board with the same process as the previous step.
4 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Huge thanks to Remington Goodwin for his EXCELLENT guide! I followed it -- successfully -- to swap out a defective board (the battery compartment microswitch had disintegrated), using a board from another "parts only" SX50 HS from Ebay. Couldn't have done the repair without his guidance.
HOWEVER -- two suggestions that will save a lot of frustration:
1. The "detached wire ribbon" (step 15) that plugs into the back of the I/O board is many (many) times easier to reattach it if you remove the front case (two small screws) and top shutter button panel (1 screw) to gain access to that ribbon cable from the front.
2. Be SUPER CAREFUL when reinserting the I/O board -- watch the almost microscopic plastic plunger on the microswitch. Have the battery door open when reinserting the I/O board; otherwise, you can easily knock that plunger out of the switch. It is so small it is almost impossible to see it -- so go slow and be careful.
Excellent DIY tutorial! Kudo's to the technician!
