Ga door naar hoofdinhoud
Canon PowerShot SX50 HS Function Dial Replacement
Wat je nodig hebt
  1. Canon PowerShot SX50 HS Function Dial Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon PowerShot SX50 HS Function Dial Replacement: stap 2, afbeelding 1 van 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: stap 3, afbeelding 1 van 2 Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: stap 3, afbeelding 2 van 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
    Vraag FixBot
    Voeg opmerking toe
  4. Canon PowerShot SX50 HS Function Dial Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX50 HS Function Dial Replacement: stap 4, afbeelding 2 van 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
    Vraag FixBot
    Voeg opmerking toe
  5. Canon PowerShot SX50 HS Function Dial Replacement: stap 5, afbeelding 1 van 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon PowerShot SX50 HS Function Dial Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot SX50 HS Function Dial Replacement: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
    Vraag FixBot
    Voeg opmerking toe
  7. Canon PowerShot SX50 HS Function Dial Replacement: stap 7, afbeelding 1 van 3 Canon PowerShot SX50 HS Function Dial Replacement: stap 7, afbeelding 2 van 3 Canon PowerShot SX50 HS Function Dial Replacement: stap 7, afbeelding 3 van 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
    Vraag FixBot
    Voeg opmerking toe
  8. Canon PowerShot SX50 HS Function Dial Replacement: stap 8, afbeelding 1 van 3 Canon PowerShot SX50 HS Function Dial Replacement: stap 8, afbeelding 2 van 3 Canon PowerShot SX50 HS Function Dial Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
    Vraag FixBot
    Voeg opmerking toe
  9. Canon PowerShot SX50 HS Function Dial Replacement: stap 9, afbeelding 1 van 1
    • Now you can completely separate the back encasement from the rest of the camera.
    Vraag FixBot
    Voeg opmerking toe
  10. Canon PowerShot SX50 HS Function Dial Replacement, Function Dial: stap 10, afbeelding 1 van 1
    • Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
    Vraag FixBot
    Voeg opmerking toe
  11. Canon PowerShot SX50 HS Function Dial Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SX50 HS Function Dial Replacement: stap 11, afbeelding 2 van 2
    • Take off the metal plate with your fingers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Remington Goodwin
262 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-7, Lancaster Spring 2015 Lid van Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 Leden
10 handleidingen geschreven
2Gids Commentaar
Interested to know where I can buy the switch/ribbon assembly for that function dial?
Liz Comery - Antwoord Deel
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
Rita McLachlan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 33
Altijd: 1,647
