Ga door naar hoofdinhoud
Canon PowerShot SX50 HS Eyepiece Replacement
Wat je nodig hebt
  1. Canon PowerShot SX50 HS Eyepiece Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Eyepiece Replacement: stap 2, afbeelding 1 van 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Eyepiece Replacement, Rear Case: stap 3, afbeelding 1 van 2 Canon PowerShot SX50 HS Eyepiece Replacement, Rear Case: stap 3, afbeelding 2 van 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Eyepiece Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX50 HS Eyepiece Replacement: stap 4, afbeelding 2 van 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Eyepiece Replacement: stap 5, afbeelding 1 van 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Eyepiece Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot SX50 HS Eyepiece Replacement: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Eyepiece Replacement: stap 7, afbeelding 1 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 7, afbeelding 2 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 7, afbeelding 3 van 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Eyepiece Replacement: stap 8, afbeelding 1 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 8, afbeelding 2 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  9. Canon PowerShot SX50 HS Eyepiece Replacement: stap 9, afbeelding 1 van 1
    • Now you can completely separate the back encasement from the rest of the camera.
  10. Canon PowerShot SX50 HS Eyepiece Replacement, Eyepiece: stap 10, afbeelding 1 van 2 Canon PowerShot SX50 HS Eyepiece Replacement, Eyepiece: stap 10, afbeelding 2 van 2
    • Remove the two #000 Phillips screws, length 2 mm, on the metal panel attaching the eyepiece to the rest of the camera.
    • Remove the two #000 Phillips screws, length 3 mm, attaching the metal panel to the eyepiece.
  11. Canon PowerShot SX50 HS Eyepiece Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SX50 HS Eyepiece Replacement: stap 11, afbeelding 2 van 2
    • Use your fingers to carefully remove the metal plate.
    • Carefully remove the eyepiece from the encasing around it. There is a wire ribbon that will still be attaching it to the camera.
    • Do not pull the eyepiece out too hard or too fast; the wire ribbon is very delicate.
  12. Canon PowerShot SX50 HS Eyepiece Replacement: stap 12, afbeelding 1 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 12, afbeelding 2 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 12, afbeelding 3 van 3
    • Using the curved tip tweezers unhook the clasps on the sides of the eyepiece that are holding its back panel in place.
    • Using the curved tip tweezers unhook the clasp on the bottom of the eyepiece that is holding its back panel in place.
  13. Canon PowerShot SX50 HS Eyepiece Replacement: stap 13, afbeelding 1 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 13, afbeelding 2 van 3 Canon PowerShot SX50 HS Eyepiece Replacement: stap 13, afbeelding 3 van 3
    • Remove the back panel of the eyepiece. The viewfinder is inside and is attached to the camera via the orange wire ribbon.
    • Now you can completely remove the eyepiece from the camera.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Megan Rund
722 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-7, Lancaster Spring 2015 Lid van Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 2,509
