Inleiding
This guide demonstrates how to safely and properly replace the GPS in a Canon PowerShot SX280 HS. In order to do this, you will need a #00 Phillips Screwdriver, a safe place to keep the screws that will be removed, and a replacement GPS for the camera.
Wat je nodig hebt
Use your #00 Phillips Screwdriver to remove a .05/.102 screw from the proactive plate that covers the motherboard.
Once the screw is removed, the plate should lift off easily.
