Ga door naar hoofdinhoud
Canon PowerShot SX260 HS Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • *Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • There are a total of 6 (3mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • 1.) Remove the 2 screws on the left side
    • 2.) Remove the 2 screws on the bottom of the camera.
    • 3.) Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use spludger tool or small flathead screw driver to gently lift and remove back face plate.
  3. Canon PowerShot SX260 HS Motherboard Replacement: stap 3, afbeelding 1 van 1
    • After removing exterior screws, gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Motherboard Replacement: stap 4, afbeelding 1 van 1
    • After removing the front faceplate you will find 4 (3mm) screws on the interior.
    • Remove all 4 interior screws.
  5. Canon PowerShot SX260 HS Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove 1 (6 mm) Screw from the bottom of the silver metal plate. The screw is also silver
  6. Canon PowerShot SX260 HS Motherboard Replacement: stap 6, afbeelding 1 van 1
    • With blue spludger tool gently lift the metal plate from the face of the camera.
    • The plate is held by a piece of double sided tape so there will be a bit of resistance.
  7. Canon PowerShot SX260 HS Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove 3 (3 mm) screws from the top surface of the motherboard.
    • You will notice that there is one on the top, and 2 on the bottom in a triangular shape.
  8. Canon PowerShot SX260 HS Motherboard Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Gently remove the ribbon cable from the top of the motherboard with a pair of tweezers.
    • Be careful during this step not to rip or tear the cable.
  9. Canon PowerShot SX260 HS Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use the blue spludger tool to gently unplug the last ribbon cable that is attached to the motherboard.
  10. Canon PowerShot SX260 HS Motherboard Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot SX260 HS Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the motherboard with your fingers.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tyler Kelch
622 Reputatie
4 handleidingen geschreven
2 opmerkingen
Where is the internal clock/calendar battery located?
GPa Rocks - Antwoord
Internal clock battery is under circuit board on right side of lens as seen in photo for Step 9. See 2:48 - 3:19 in this video: https://www.youtube.com/watch?v=Awmm6hDm....
Paul Unger - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 33
Altijd: 2,182
