Ga door naar hoofdinhoud
Canon PowerShot SX260 HS Battery Replacement
Wat je nodig hebt
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX260 HS Battery Replacement: stap 2, afbeelding 2 van 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Conclusie
Tyler Kelch
622 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 1,119
