Ga door naar hoofdinhoud
Canon PowerShot SX160 IS Shutter Button Replacement
Wat je nodig hebt
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: stap 1, afbeelding 1 van 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: stap 1, afbeelding 2 van 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: stap 1, afbeelding 3 van 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Shutter Button Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX160 IS Shutter Button Replacement: stap 2, afbeelding 2 van 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX160 IS Shutter Button Replacement: stap 3, afbeelding 2 van 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: stap 4, afbeelding 1 van 1
    • Locate and replace the shutter button on the front panel of the camera.
Conclusie
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
1.990 Reputatie
6 handleidingen geschreven
Colorado Springs, Team 2-3, Panko Spring 2015 Lid van Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Leden
2Gids Commentaar
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Antwoord
did you ever figure out where to get a new button?
christinapayne1@icloud.com -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 43
Altijd: 3,080
