Ga door naar hoofdinhoud
Canon PowerShot SX160 IS Function Wheel Replacement
Wat je nodig hebt
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: stap 1, afbeelding 1 van 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: stap 1, afbeelding 2 van 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: stap 1, afbeelding 3 van 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX160 IS Function Wheel Replacement: stap 2, afbeelding 2 van 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX160 IS Function Wheel Replacement: stap 3, afbeelding 2 van 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: stap 4, afbeelding 1 van 1
    • Remove and replace the function wheel.
Conclusie
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
1.962 Reputatie
6 handleidingen geschreven
Colorado Springs, Team 2-3, Panko Spring 2015 Lid van Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Leden
Één opmerking
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 591
