Inleiding
Use this guide to replace a control dial on a Canon PowerShot SX120 IS.
The control dial is a feature that allows you to perform different operations like switching images or choosing items. When the control dial is broken it can become difficult to navigate through different features that the camera offers.
Before beginning this process, make sure to remove the double AA batteries. To remove the batteries, slide and hold the cover lock on the top corner of the camera, then slide and open the cover.
Wat je nodig hebt
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
Use a pair of tweezers to remove the old control dial and set the new control in the same place.
Één andere persoon heeft deze handleiding voltooid.
