Inleiding
This guide will take you through the process of replacing a broken screen on a Canon PowerShot SX120 IS.
Wat je nodig hebt
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Remove the two screws that are attached directly below the screen with a #000 philips screw driver. These screws secure the screen to the main frame of the camera.
Remove the two 3.4 mm screws
Leave the camera facing down and locate the ribbon connector. The ribbon connector is placed bellow the main button panel on the bottom right side of the camera.
Lift the main button panel and gently hold the ribbon connector with the black tweezers.
Once the ribbon has been entirely disconnected, lift the entire panel and place it above it's original positions. The panel will not be entirely removed only the lower half.
Place the camera with the lens facing down.
Use the black tweezers to gently begin to lift the screen. Begin lifting the screen from the left side.
Locate the ribbon connector that is attached to the screen and also the motherboard.
Remove the ribbon from the motherboard connection by flipping up the small black clamp on the connector with a spudger.
Één andere persoon heeft deze handleiding voltooid.
