Ga door naar hoofdinhoud
Canon PowerShot SD960 IS LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot SD960 IS LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS LCD Screen Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
  4. Canon PowerShot SD960 IS LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Working on your electronic device while it is powered on can result in electric shock. Power off, unplug, and remove the battery of your device before continuing.
    • Close the battery door, and turn the camera over so that the bottom of the camera is facing up.
    • Using a PH000 screwdriver, remove the two 5.5mm screws.
  5. Canon PowerShot SD960 IS LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Turn the camera over to the side
    • Remove the two 4mm PH000 screws from the side of the camera.
  6. Canon PowerShot SD960 IS LCD Screen Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Turn camera over to the data port side with the panel that reads A/V Out.
    • Lift open the latch that covers the camera's data ports.
    • Remove the one 2.4mm PH000 screw on the left.
    • Remove the one 4mm PH000 screw on the right.
  7. Canon PowerShot SD960 IS LCD Screen Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Turn the camera over so the lens is facing up.
    • Remove the front cover.
  8. Canon PowerShot SD960 IS LCD Screen Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Turn the camera over so that the screen is facing up.
    • Remove the back cover.
  9. Canon PowerShot SD960 IS LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove two 2.4mm PH000 screws from the plate on the front of camera.
    • Gently remove the plate.
  10. Canon PowerShot SD960 IS LCD Screen Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Turn the camera over to the data port side again.
    • After removing the front panel in the previous step, the AV/OUT panel should be free to remove. Gently slide out the A/V panel.
  11. Canon PowerShot SD960 IS LCD Screen Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Turn the camera over so the top panel that reads "Image Stabilizer" is facing up.
    • Remove the two 2.4mm PH000 screws from the top of the camera to the left of the power on/off switch.
    • Gently remove the panel from the side of the camera.
  12. Canon PowerShot SD960 IS LCD Screen Replacement: stap 12, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 12, afbeelding 2 van 2
    • Turn the camera over so the screen is facing up.
    • Remove one 3.2mm PH000 screw from the top of the LCD screen.
    • Remove one 3.2mm PH000 screw from the bottom of the LCD screen.
  13. Canon PowerShot SD960 IS LCD Screen Replacement: stap 13, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • When you remove the top panel it will remain attached by a small orange cable. You can leave the cable attached; it will not obstruct you from completing the following steps.
    • Gently remove the top panel.
  14. Canon PowerShot SD960 IS LCD Screen Replacement: stap 14, afbeelding 1 van 1
    • Remove two 3.2mm PH000 screws on the side of the camera, to the right of the button that reads "Func. Set."
  15. Canon PowerShot SD960 IS LCD Screen Replacement: stap 15, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 15, afbeelding 2 van 2
    • Use a nylon spudger to flip open the teeth holding the small, orange data cable in place.
    • Gently remove the small, orange data cable. The cable should now hang free.
  16. Canon PowerShot SD960 IS LCD Screen Replacement: stap 16, afbeelding 1 van 1
    • Once the data cable is removed, the panel to the right of the LCD screen with the button that reads "Func. Set" will be free to remove.
    • Gently remove the panel to the right of the LCD screen.
  17. Canon PowerShot SD960 IS LCD Screen Replacement: stap 17, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 17, afbeelding 2 van 2
    • Locate the large, yellow data cable by turning the camera over so the lens is facing up.
    • Find where the data cable connects on the front of the camera.
  18. Canon PowerShot SD960 IS LCD Screen Replacement: stap 18, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 18, afbeelding 2 van 2
    • Use a nylon spudger to flip open the teeth that are holding the large, yellow data cable in place.
    • Gently remove the data cable.
  19. Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 3 van 3
    • Remove the LCD screen.
  20. Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 3 van 3
    • To remove the casing around the LCD screen, begin by removing the top of the casing (which is in two pieces). First, remove the small hinge on the right side.
    • Then, remove the rest of the casing.
    • The top of the LCD screen casing should now be removed.
  21. Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 3 van 3
    • Carefully slide out the LCD screen from the back part of the casing.
    • You should now have three components: The back of the LCD screen casing, the LCD screen, and the front of the LCD screen casing.
    • The LCD screen is now removed and can be replaced or set aside to access other camera components.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kacy Ewing
253 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,176
