Ga door naar hoofdinhoud
Canon PowerShot SD960 IS LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot SD960 IS LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera over so that the bottom of the camera is facing up.
    Vraag FixBot
  2. Canon PowerShot SD960 IS LCD Screen Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
    Vraag FixBot
  3. Canon PowerShot SD960 IS LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
    Vraag FixBot
  4. Canon PowerShot SD960 IS LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Working on your electronic device while it is powered on can result in electric shock. Power off, unplug, and remove the battery of your device before continuing.
    • Close the battery door, and turn the camera over so that the bottom of the camera is facing up.
    • Using a PH000 screwdriver, remove the two 5.5mm screws.
    Vraag FixBot
  5. Canon PowerShot SD960 IS LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Turn the camera over to the side
    • Remove the two 4mm PH000 screws from the side of the camera.
    Vraag FixBot
  6. Canon PowerShot SD960 IS LCD Screen Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Turn camera over to the data port side with the panel that reads A/V Out.
    • Lift open the latch that covers the camera's data ports.
    • Remove the one 2.4mm PH000 screw on the left.
    • Remove the one 4mm PH000 screw on the right.
    Vraag FixBot
  7. Canon PowerShot SD960 IS LCD Screen Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Turn the camera over so the lens is facing up.
    • Remove the front cover.
    Vraag FixBot
  8. Canon PowerShot SD960 IS LCD Screen Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Turn the camera over so that the screen is facing up.
    • Remove the back cover.
    Vraag FixBot
  9. Canon PowerShot SD960 IS LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove two 2.4mm PH000 screws from the plate on the front of camera.
    • Gently remove the plate.
    Vraag FixBot
  10. Canon PowerShot SD960 IS LCD Screen Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Turn the camera over to the data port side again.
    • After removing the front panel in the previous step, the AV/OUT panel should be free to remove. Gently slide out the A/V panel.
    Vraag FixBot
  11. Canon PowerShot SD960 IS LCD Screen Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Turn the camera over so the top panel that reads "Image Stabilizer" is facing up.
    • Remove the two 2.4mm PH000 screws from the top of the camera to the left of the power on/off switch.
    • Gently remove the panel from the side of the camera.
    Vraag FixBot
  12. Canon PowerShot SD960 IS LCD Screen Replacement: stap 12, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 12, afbeelding 2 van 2
    • Turn the camera over so the screen is facing up.
    • Remove one 3.2mm PH000 screw from the top of the LCD screen.
    • Remove one 3.2mm PH000 screw from the bottom of the LCD screen.
    Vraag FixBot
  13. Canon PowerShot SD960 IS LCD Screen Replacement: stap 13, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • When you remove the top panel it will remain attached by a small orange cable. You can leave the cable attached; it will not obstruct you from completing the following steps.
    • Gently remove the top panel.
    Vraag FixBot
  14. Canon PowerShot SD960 IS LCD Screen Replacement: stap 14, afbeelding 1 van 1
    • Remove two 3.2mm PH000 screws on the side of the camera, to the right of the button that reads "Func. Set."
    Vraag FixBot
  15. Canon PowerShot SD960 IS LCD Screen Replacement: stap 15, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 15, afbeelding 2 van 2
    • Use a nylon spudger to flip open the teeth holding the small, orange data cable in place.
    • Gently remove the small, orange data cable. The cable should now hang free.
    Vraag FixBot
  16. Canon PowerShot SD960 IS LCD Screen Replacement: stap 16, afbeelding 1 van 1
    • Once the data cable is removed, the panel to the right of the LCD screen with the button that reads "Func. Set" will be free to remove.
    • Gently remove the panel to the right of the LCD screen.
    Vraag FixBot
  17. Canon PowerShot SD960 IS LCD Screen Replacement: stap 17, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 17, afbeelding 2 van 2
    • Locate the large, yellow data cable by turning the camera over so the lens is facing up.
    • Find where the data cable connects on the front of the camera.
    Vraag FixBot
  18. Canon PowerShot SD960 IS LCD Screen Replacement: stap 18, afbeelding 1 van 2 Canon PowerShot SD960 IS LCD Screen Replacement: stap 18, afbeelding 2 van 2
    • Use a nylon spudger to flip open the teeth that are holding the large, yellow data cable in place.
    • Gently remove the data cable.
    Vraag FixBot
  19. Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 19, afbeelding 3 van 3
    • Remove the LCD screen.
    Vraag FixBot
  20. Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 20, afbeelding 3 van 3
    • To remove the casing around the LCD screen, begin by removing the top of the casing (which is in two pieces). First, remove the small hinge on the right side.
    • Then, remove the rest of the casing.
    • The top of the LCD screen casing should now be removed.
    Vraag FixBot
  21. Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 1 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 2 van 3 Canon PowerShot SD960 IS LCD Screen Replacement: stap 21, afbeelding 3 van 3
    • Carefully slide out the LCD screen from the back part of the casing.
    • You should now have three components: The back of the LCD screen casing, the LCD screen, and the front of the LCD screen casing.
    • The LCD screen is now removed and can be replaced or set aside to access other camera components.
    Vraag FixBot
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kacy Ewing
253 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 64
Altijd: 1,409
