Inleiding
Use this repair guide to replace a broken LCD screen on your Canon PowerShot SD850 IS.
Wat je nodig hebt
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
Één andere persoon heeft deze handleiding voltooid.
