Ga door naar hoofdinhoud
Inleiding
Use this guide to access LCD screen and make repairs.
  1. Using your fingernail, slide the light gray tab towards edge of camera. Slide the light gray door and pull up to open the door. In the camera shown in the photos, there is not a Memory Card or Battery.
    • Using your fingernail, slide the light gray tab towards edge of camera.
    • Slide the light gray door and pull up to open the door.
    • In the camera shown in the photos, there is not a Memory Card or Battery.
    • Both Battery and Memory Card slots should be visible.
  2. Use your fingernail and slide the small brown tab towards the edge of the camera. The battery will pop up.
    • Use your fingernail and slide the small brown tab towards the edge of the camera.
    • The battery will pop up.
    • Pull battery straight out of battery holder.
    • When putting the battery back in, make sure it the battery is oriented so the terminals connect.
  3. Remove the following 4 screws: Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Open the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap. Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera. Slide light gray door and pull up to open the door.
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera. Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Remove the three screws attached to the bottom of the LCD brackets Remove the three screws attached to the bottom of the LCD brackets
    • Remove the three screws attached to the bottom of the LCD brackets
  10. Remove the one quarter bracket around the LCD screen Remove the three quarter bracket around the LCD screen.
    • Remove the one quarter bracket around the LCD screen
    • Remove the three quarter bracket around the LCD screen.
  11. Please Note: There are two areas of interest before removing the final bracket. First, use a spudger to pry the the two tabs from the small guide pins. Second, slide the bracket to the right as indicated in the second picture while lifting up. A small tab is holding the final bracket in place.
    • Please Note: There are two areas of interest before removing the final bracket.
    • First, use a spudger to pry the the two tabs from the small guide pins.
    • Second, slide the bracket to the right as indicated in the second picture while lifting up. A small tab is holding the final bracket in place.
    • Remove the square metal bracket.
  12. At this point the screen should be easy to lift from the camera body.
    • At this point the screen should be easy to lift from the camera body.
  13. Lift the LCD screen and remove the two ribbon cables. Lift the LCD screen and remove the two ribbon cables. Lift the LCD screen and remove the two ribbon cables.
    • Lift the LCD screen and remove the two ribbon cables.
Conclusie
iDeleted
2.101 Reputatie
39 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,520
