Ga door naar hoofdinhoud
Canon PowerShot SD850 IS Function Set Button Replacement
Wat je nodig hebt
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: stap 1, afbeelding 1 van 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: stap 1, afbeelding 2 van 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SD850 IS Function Set Button Replacement: stap 2, afbeelding 2 van 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: stap 3, afbeelding 1 van 2 Canon PowerShot SD850 IS Function Set Button Replacement, Case: stap 3, afbeelding 2 van 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: stap 4, afbeelding 1 van 3 Canon PowerShot SD850 IS Function Set Button Replacement: stap 4, afbeelding 2 van 3 Canon PowerShot SD850 IS Function Set Button Replacement: stap 4, afbeelding 3 van 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot SD850 IS Function Set Button Replacement: stap 5, afbeelding 2 van 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot SD850 IS Function Set Button Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: stap 8, afbeelding 1 van 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: stap 9, afbeelding 1 van 2 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: stap 9, afbeelding 2 van 2
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: stap 10, afbeelding 1 van 1
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: stap 11, afbeelding 1 van 1
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
Conclusie
iDeleted
2.101 Reputatie
39 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,149
