Ga door naar hoofdinhoud
Canon PowerShot SD850 IS Camera Lens Replacement
Wat je nodig hebt
  1. Canon PowerShot SD850 IS Camera Lens Replacement, Case: stap 1, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement, Case: stap 1, afbeelding 2 van 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  2. Canon PowerShot SD850 IS Camera Lens Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot SD850 IS Camera Lens Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot SD850 IS Camera Lens Replacement: stap 2, afbeelding 3 van 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  3. Canon PowerShot SD850 IS Camera Lens Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 3, afbeelding 2 van 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  4. Canon PowerShot SD850 IS Camera Lens Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 4, afbeelding 2 van 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  5. Canon PowerShot SD850 IS Camera Lens Replacement: stap 5, afbeelding 1 van 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  6. Canon PowerShot SD850 IS Camera Lens Replacement: stap 6, afbeelding 1 van 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  7. Canon PowerShot SD850 IS Camera Lens Replacement, LCD Screen: stap 7, afbeelding 1 van 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  8. Canon PowerShot SD850 IS Camera Lens Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  9. Canon PowerShot SD850 IS Camera Lens Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 9, afbeelding 2 van 2
    • Remove the two metal frames that hold the LCD panel in place.
  10. Canon PowerShot SD850 IS Camera Lens Replacement: stap 10, afbeelding 1 van 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  11. Canon PowerShot SD850 IS Camera Lens Replacement: stap 11, afbeelding 1 van 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  12. Canon PowerShot SD850 IS Camera Lens Replacement: stap 12, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 12, afbeelding 2 van 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD850 IS Camera Lens Replacement, Flash Unit: stap 13, afbeelding 1 van 1
    • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
  14. Canon PowerShot SD850 IS Camera Lens Replacement: stap 14, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 14, afbeelding 2 van 2
    • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
    • Next use the tweezers to carefully remove the speaker cable off its respective holders.
  15. Canon PowerShot SD850 IS Camera Lens Replacement: stap 15, afbeelding 1 van 1
    • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
  16. Canon PowerShot SD850 IS Camera Lens Replacement: stap 16, afbeelding 1 van 2 Canon PowerShot SD850 IS Camera Lens Replacement: stap 16, afbeelding 2 van 2
    • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
    • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
  17. Canon PowerShot SD850 IS Camera Lens Replacement: stap 17, afbeelding 1 van 1
    • Gently remove the flash component from the rest of the camera.
    • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
  18. Canon PowerShot SD850 IS Camera Lens Replacement, Camera Lens: stap 18, afbeelding 1 van 1
    • Remove four screws located on the back of the camera:
    • 6.15 mm #00 Phillips
    • 2.75 mm #00 Phillips
    • 2.15 mm #00 Phillips
    • 2.7 mm #00 Phillips
  19. Canon PowerShot SD850 IS Camera Lens Replacement: stap 19, afbeelding 1 van 1
    • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
  20. Canon PowerShot SD850 IS Camera Lens Replacement: stap 20, afbeelding 1 van 1
    • Gently remove the camera lens from the rest of the camera.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Peter Tran
225 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-7, Maness Fall 2010 Lid van Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Leden
7 handleidingen geschreven
Één opmerking
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
Jerome Tenedero - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 14,114
