Ga door naar hoofdinhoud
Canon PowerShot SD700 Outside Case Replacement
Wat je nodig hebt
  1. Canon PowerShot SD700 Outside Case Replacement, Outside Case: stap 1, afbeelding 1 van 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Outside Case Replacement: stap 2, afbeelding 1 van 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Outside Case Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Outside Case Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Outside Case Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Outside Case Replacement: stap 6, afbeelding 1 van 1
    • Remove the front, back, and side casings from the camera and set to the side.
Conclusie
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Emilio Rossi
113 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-71, Walters Spring 2011 Lid van Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 1,474
