Ga door naar hoofdinhoud
Canon PowerShot SD700 LCD screen Replacement
Wat je nodig hebt
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: stap 1, afbeelding 1 van 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: stap 7, afbeelding 1 van 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: stap 8, afbeelding 1 van 3 Canon PowerShot SD700 LCD screen Replacement: stap 8, afbeelding 2 van 3 Canon PowerShot SD700 LCD screen Replacement: stap 8, afbeelding 3 van 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
Conclusie
Emilio Rossi
113 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-71, Walters Spring 2011 Lid van Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,624
