Ga door naar hoofdinhoud
Canon PowerShot SD500 Digital ELPH Shutter Button Replacement
Wat je nodig hebt
  1. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Front and Rear Casing: stap 3, afbeelding 1 van 2 Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Front and Rear Casing: stap 3, afbeelding 2 van 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 4, afbeelding 1 van 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 5, afbeelding 1 van 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 6, afbeelding 1 van 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 7, afbeelding 1 van 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 8, afbeelding 1 van 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 9, afbeelding 2 van 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement, Shutter Button: stap 10, afbeelding 1 van 1
    • Unscrew one .235 inch long Phillips screw using a #00 Phillips screwdriver from the top of the camera.
  11. Canon PowerShot SD500 Digital ELPH Shutter Button Replacement: stap 11, afbeelding 1 van 1
    • Gently remove the shutter button unit from the rest of the camera.
Conclusie
Taylor Shields
846 Reputatie
8 handleidingen geschreven
Clemson, Team 2-1, Benson Fall 2014 Lid van Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 156
