Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
You need to remove the casing before you can start getting into any internal parts of the Camera. This can also be a good start to helping the camera dry out in case of a water accident.
Wat je nodig hebt
Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Één andere persoon heeft deze handleiding voltooid.
