Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the 6 screws that you must remove to open the camera housing.
There are 2 screws on the bottom and 2 screws on each side
Using the screwdriver, carefully remove the exterior screws and set them aside to avoid misplacing them.
Locate the interior screw to the top right of the screen.
Remove the screw using the screwdriver.
Insert the flat-head screwdriver under the LCD screen into the two clips.
Lift the LCD screen.
