Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
    • There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
  2. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  3. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
    • Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
  4. Open the case gently. The wrist strap plate and disk pieces will fall out during the process.  The second picture shows what wrist strap plate and disk looks like (The circled parts). Replace the broken camera case with the new one.
    • Open the case gently. The wrist strap plate and disk pieces will fall out during the process. The second picture shows what wrist strap plate and disk looks like (The circled parts).
    • Replace the broken camera case with the new one.
Conclusie
Yi Huang Ke
51 Reputatie
4 handleidingen geschreven
James Madison, Team 1-1, Allen Fall 2011 Lid van James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 6
Altijd: 1,724
