Inleiding
Follow the steps in this guide to remove and replace the motherboard of the camera. Damage to the motherboard will cause other components to fail.
Wat je nodig hebt
Remove the 2mm screw from the back of the camera.
Remove two 2mm screws from the bottom of the camera.
Remove two 2mm screws the left side of camera.
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
Unscrew the 3mm silver screw from the top of the camera.
Gently remove the top button panel.
Één andere persoon heeft deze handleiding voltooid.
