Ga door naar hoofdinhoud
Canon PowerShot SD1400 IS Battery Replacement
Wat je nodig hebt
  1. Canon PowerShot SD1400 IS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery compartment is located on the bottom of the camera, below the user interface panel.
  2. Canon PowerShot SD1400 IS Battery Replacement: stap 2, afbeelding 1 van 1
    • The hatch covering the memory card will slide open towards the corner of the device.
  3. Canon PowerShot SD1400 IS Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
  4. Canon PowerShot SD1400 IS Battery Replacement: stap 4, afbeelding 1 van 1
    • Once open, you will see a small orange tab near the corner of the camera.
    • Push this tab towards the front face of the device, and the battery will freely fall out from the hatch.
Conclusie
Matt Holquist
136 Reputatie
1 Handleiding geschreven
Baylor, Team S1-G3, Johnson Spring 2018 Lid van Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 59
Altijd: 1,460
