Inleiding
This guide will show you how to properly replace a faulty lens on your Canon PowerShot SD1300 IS.
Wat je nodig hebt
Remove the two 2mm J00 screws on the right exterior.
Remove a single 4 mm J00 on the bottom exterior.
Remove a single 3mm J00 on the left exterior.
Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
Één opmerking
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
