Ga door naar hoofdinhoud
Canon PowerShot SD1300 IS Lens Replacement
Wat je nodig hebt
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: stap 1, afbeelding 1 van 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: stap 1, afbeelding 2 van 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: stap 1, afbeelding 3 van 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: stap 2, afbeelding 1 van 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: stap 3, afbeelding 1 van 1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: stap 4, afbeelding 1 van 1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
Conclusie
Clayton
560 Reputatie
5 handleidingen geschreven
Texas Tech, Team S13-G1, Bennett Spring 2017 Lid van Texas Tech, Team S13-G1, Bennett Spring 2017
TTU-BENNETT-S17S13G1
5 Leden
Één opmerking
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 49
Altijd: 1,266
