Ga door naar hoofdinhoud
Canon PowerShot SD1200 IS Motherboard
Wat je nodig hebt
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: stap 1, afbeelding 1 van 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: stap 2, afbeelding 1 van 3 Canon PowerShot SD1200 IS Motherboard: stap 2, afbeelding 2 van 3 Canon PowerShot SD1200 IS Motherboard: stap 2, afbeelding 3 van 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: stap 3, afbeelding 1 van 2 Canon PowerShot SD1200 IS Motherboard: stap 3, afbeelding 2 van 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: stap 4, afbeelding 1 van 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: stap 5, afbeelding 1 van 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: stap 6, afbeelding 1 van 2 Canon PowerShot SD1200 IS Motherboard: stap 6, afbeelding 2 van 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: stap 7, afbeelding 1 van 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: stap 8, afbeelding 1 van 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: stap 9, afbeelding 1 van 1
    • Lift out the motherboard.
Conclusie
Jeff Casper
848 Reputatie
7 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Fall 2016 Lid van USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 435
