Ga door naar hoofdinhoud
Canon PowerShot SD1200 IS Function Button Board Replacement
Wat je nodig hebt
  1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: stap 1, afbeelding 1 van 1
    • Remove the battery.
    Vraag FixBot
  2. Canon PowerShot SD1200 IS Function Button Board Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot SD1200 IS Function Button Board Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot SD1200 IS Function Button Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
    Vraag FixBot
  3. Canon PowerShot SD1200 IS Function Button Board Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SD1200 IS Function Button Board Replacement: stap 3, afbeelding 2 van 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
    Vraag FixBot
  4. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: stap 4, afbeelding 1 van 1
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable from the connector.
    Vraag FixBot
  5. Canon PowerShot SD1200 IS Function Button Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the top screw from the function button board. (3.5mm Phillips 00)
    • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
    Vraag FixBot
  6. Canon PowerShot SD1200 IS Function Button Board Replacement: stap 6, afbeelding 1 van 1
    • Lift out the function button board.
    Vraag FixBot
Conclusie
Jeff Casper
897 Reputatie
7 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Fall 2016 Lid van USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 519
