Inleiding
Use the guide to remove the flash assembly.
Wat je nodig hebt
Remove the top-left screw above the LCD screen (0.100 in).
Remove the C-shaped plate from the side of the LCD screen.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Step 14 The little hook at the bottom that holds the flash assembly in is hard to see. It is part of the bracket that holds the flash in and also forms part of the chassis of the camera. I found that you can gently flex the bracket outward ( away from the flash) to release the hook. After that, the flash unit came right out. Also note, that some flash units you get from electronics scrapers on ebay will have the bracket attached to the flash unit and it needs to be removed before you install the replacement part. It seems obvious but then again...
