Ga door naar hoofdinhoud
Canon PowerShot SD1000 LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: stap 6, afbeelding 1 van 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot SD1000 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot SD1000 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 LCD Screen Replacement: stap 12, afbeelding 1 van 3 Canon PowerShot SD1000 LCD Screen Replacement: stap 12, afbeelding 2 van 3 Canon PowerShot SD1000 LCD Screen Replacement: stap 12, afbeelding 3 van 3
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
Conclusie
Phillip Phung
651 Reputatie
9 handleidingen geschreven
Cal Poly, Team 8-18, Maness Winter 2012 Lid van Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Leden
12 handleidingen geschreven
Één opmerking
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
George Francis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 27
Altijd: 3,508
