Ga door naar hoofdinhoud
Canon PowerShot SD1000 Front Case Replacement
Wat je nodig hebt
  1. Canon PowerShot SD1000 Front Case Replacement, Back Panel: stap 1, afbeelding 1 van 2 Canon PowerShot SD1000 Front Case Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Front Case Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Front Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Front Case Replacement: stap 4, afbeelding 1 van 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Front Case Replacement: stap 5, afbeelding 1 van 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Front Case Replacement, Front Case: stap 6, afbeelding 1 van 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Front Case Replacement: stap 7, afbeelding 1 van 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Conclusie
Phillip Phung
651 Reputatie
9 handleidingen geschreven
Cal Poly, Team 8-18, Maness Winter 2012 Lid van Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,360
