Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide is for replacing the speaker on your Canon PowerShot S80. If you have already checked your volume settings and the speaker still does not give audio cues when the camera is in use, this guide will help you replace the faulty speaker.
Wat je nodig hebt
Remove the knot on the wrist lanyard.
Remove the battery and the memory card.
Remove the screw and unplug the wire lead.
Gently remove the speaker from the camera body.
