Ga door naar hoofdinhoud
Canon PowerShot S80 Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot S80 Motherboard Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot S80 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: stap 4, afbeelding 1 van 3 Canon PowerShot S80 Motherboard Replacement: stap 4, afbeelding 2 van 3 Canon PowerShot S80 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: stap 5, afbeelding 1 van 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: stap 10, afbeelding 1 van 3 Canon PowerShot S80 Motherboard Replacement: stap 10, afbeelding 2 van 3 Canon PowerShot S80 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: stap 12, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: stap 13, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: stap 15, afbeelding 1 van 3 Canon PowerShot S80 Motherboard Replacement: stap 15, afbeelding 2 van 3 Canon PowerShot S80 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: stap 18, afbeelding 1 van 2 Canon PowerShot S80 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Use a spudger to gently lift the motherboard from the camera.
Conclusie
BrettH
219 Reputatie
5 handleidingen geschreven
Cal Poly, Team 19-5, Maness SU 2012 Lid van Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Lid
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 4,418
