Ga door naar hoofdinhoud
Canon PowerShot S500 Logic Board Replacement
Wat je nodig hebt
  1. Canon PowerShot S500 Logic Board Replacement, Front and Rear Casing : stap 1, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement, Front and Rear Casing : stap 1, afbeelding 2 van 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Logic Board Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
  6. Canon PowerShot S500 Logic Board Replacement, LCD: stap 6, afbeelding 1 van 1
    • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
  7. Canon PowerShot S500 Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Gently separate the top of LCD from the rest of the camera using your thumb.
    • Be careful not pull the LCD too far because of the ribbon cable connection.
    • Place the Spudger in the hole of the electrical ribbon.
    • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
    • The LCD will still be connected to the rest of the camera
  8. Canon PowerShot S500 Logic Board Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement: stap 8, afbeelding 2 van 2
    • Unscrew single Phillips screw with a #0 Phillips screwdriver.
    • Free the bottom panel and attached ribbon from the rest of the camera.
    • Be careful not to damage the ribbon.
  9. Canon PowerShot S500 Logic Board Replacement: stap 9, afbeelding 1 van 1
    • Turn over the camera.
    • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
    • The plastic will still be connected on the left side.
  10. Canon PowerShot S500 Logic Board Replacement: stap 10, afbeelding 1 van 1
    • Place the Spudger between the orange ribbon and the black ribbon gate.
    • Lift the ribbon gate using the Spudger.
  11. Canon PowerShot S500 Logic Board Replacement: stap 11, afbeelding 1 van 1
    • Place the Spudger in the corner of the ribbon above the hole.
    • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
  12. Canon PowerShot S500 Logic Board Replacement: stap 12, afbeelding 1 van 1
    • Free this ribbon and the bottom panel from the rest of the camera.
  13. Canon PowerShot S500 Logic Board Replacement: stap 13, afbeelding 1 van 1
    • Turn the camera over so you can see the LCD.
    • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
  14. Canon PowerShot S500 Logic Board Replacement: stap 14, afbeelding 1 van 1
    • Lift the blue ribbon gate using the Spudger.
  15. Canon PowerShot S500 Logic Board Replacement: stap 15, afbeelding 1 van 1
    • Insert the Spudger into the hole of the ribbon.
    • Move the Spudger away from the gate to fully remove ribbon.
  16. Canon PowerShot S500 Logic Board Replacement: stap 16, afbeelding 1 van 1
    • Lift the LCD away from the rest of the camera.
  17. Canon PowerShot S500 Logic Board Replacement, Logic Board: stap 17, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement, Logic Board: stap 17, afbeelding 2 van 2
    • Lift off the capture button by wiggling it back and forth while pulling upward.
    • Be careful not to damage the two clips.
  18. Canon PowerShot S500 Logic Board Replacement: stap 18, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement: stap 18, afbeelding 2 van 2
    • Flip open the four ribbon gates using the Spudger.
    • Gently pull out the ribbon cables from the gates using the Spudger.
  19. Canon PowerShot S500 Logic Board Replacement: stap 19, afbeelding 1 van 1
    • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
  20. Canon PowerShot S500 Logic Board Replacement: stap 20, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement: stap 20, afbeelding 2 van 2
    • Gently lift the logic board.
    • Be careful not to pull too hard and damage the white ribbon cable.
    • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
    • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
  21. Canon PowerShot S500 Logic Board Replacement: stap 21, afbeelding 1 van 1
    • Lay the logic board back down so that it is resting on the body of the camera.
    • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
  22. Canon PowerShot S500 Logic Board Replacement: stap 22, afbeelding 1 van 2 Canon PowerShot S500 Logic Board Replacement: stap 22, afbeelding 2 van 2
    • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
    • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
    • Desolder the two soldered ribbon cables attached to the logic board.
  23. Canon PowerShot S500 Logic Board Replacement: stap 23, afbeelding 1 van 1
    • Free the logic board from the rest of the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Balcom
81 Reputatie
8 handleidingen geschreven
Cal Poly, Team 16-28, Maness Winter 2010 Lid van Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Leden
Één opmerking
How brilliant! Great pictures! But where did you buy the new logic board?
Rosario - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,786
