Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide shows you how to remove and replace the front cover of the camera.
Wat je nodig hebt
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws.
Remove the two 3.8mm screws near the strap bracket.
Remove small panel covering mounting bracket.
Remove door covering memory card.
