Ga door naar hoofdinhoud
Canon PowerShot S400 Shutter Button Assembly Replacement
Wat je nodig hebt
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: stap 1, afbeelding 1 van 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: stap 1, afbeelding 2 van 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot S400 Shutter Button Assembly Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot S400 Shutter Button Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot S400 Shutter Button Assembly Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot S400 Shutter Button Assembly Replacement: stap 3, afbeelding 3 van 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Conclusie
Ross Bryan
374 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-19, Amido Winter 2011 Lid van Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 2,731
