Inleiding
This camera has a GPS that tracks where pictures have been taken. If the GPS board malfunctions, it can be removed and replaced.
Wat je nodig hebt
Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
Turn the camera over on its side so that the terminals are facing you.
Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
Turn the camera over so that the camera lens is facing you.
Using the spudger, detach the ribbon cable that is connecting the GPS tracker to the motherboard.
