Inleiding
The control dial on the back of the camera can be removed and replaced.The control dial is used to adjust the camera's settings and navigate the camera menus.
Wat je nodig hebt
Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
Turn the camera over so that the LCD screen is facing you.
Remove the screw (3.9mm, Phillips #00) that is attaching the thin metal frame to the camera.
Remove the 2 screws (3.1mm, Phillips #00) that are attaching the control dial panel to the camera.
Één opmerking
I have Canon S100 and it was stuck. Can I send this camera to you to get it fixed and if so, what is your address and how much it will cost?
