Ga door naar hoofdinhoud
Canon PowerShot G7X Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot G7X Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Remove the four 2mm Phillips screws from the back of the screen.
  2. Canon PowerShot G7X Screen Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot G7X Screen Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot G7X Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 2mm Phillips #000 around the edge of the screen.
  3. Canon PowerShot G7X Screen Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot G7X Screen Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot G7X Screen Replacement: stap 3, afbeelding 3 van 3
    • Using the plastic opening tool, pry back the backplate from the front of the screen.
  4. Canon PowerShot G7X Screen Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot G7X Screen Replacement: stap 4, afbeelding 2 van 2
    • Using the black nylon spudger, gently remove the ribbon cable.
    • Remove the LCD screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
This is good and was a big help replacing my cracked G7 X display, but a few additional things worth noting
The ribbon connectors are ZIF. Be sure to flip up the little flaps to release them.
To replace the LCD panel, two additional steps are needed:
Remove the PCB. It’s held on with a strip of adhesive, and can be removed by slowly, gently prying it up with a plastic spudger from the exposed edges.
The panel itself is held into the frame by strips of tar like adhesive around the edges. I got it out with a combination of prying between the display and the plastic back of the frame though the opening left by the PCB, a suction cup on the front, and working around the edges. The glass is very delicate, it’s easy to crack prying around the edges or bending the frame . The adhesive can be reused to an extent, but the fit may not be as nice as factory.
reyalp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 2,985
